gofar99 Messages: 2059 Registered: May 2010 Location: Southern Arizona
Hi, Absolutely standing upright, but arranged with some sort of support so they don't tilt. At room temperature and to protect the jackets use clear plastic sleeves. Inside the jackets I like to use MoFi liners. Not expensive and they keep the vinyl protected. I'm not a huge collector but I figure I have around 500 lps. Six turntables and lots of other gear. Most well kept LPs last forever if played on good gear. I have many that are the original pressings from as much as 50 years ago. They play fine. Something not asked was about cleaning them. There are many ways as low cost as a "Spin Clean" (under $100) to mega dollars. I use a diy ultrasonic cleaner. Grunge in the grooves is one of the major causes of poor sound. An anti static dust brush is indispensable as well. Dust the LP just before playing to reduce (but unfortunately not eliminate) groove dust. Lots of other thing you can do as well and if you are getting serious you should visit the vinylengine.com forums.
