Home » Audio » Thermionic Emissions » Why parafeed?
Re: Why parafeed? [message #87874 is a reply to message #86325] Tue, 24 April 2018 21:04 Go to previous messageGo to previous message
hudelson2 is currently offline  hudelson2
Normally the primary of the output transformer is connected to B+ voltage and the plate of the output tube. In a single ended amplifier there is direct current passing though the output transformer. There has to be a gap in the core to keep the core from being saturated. Then you need an expensive large transformer to pass low frequencies.
Parallel feed (parafeed) has the DC passing through a separate inductor from B+ voltage to plate of the output tube. There is a DC blocking capacitor to the output transformer. Since there is no DC passing through the output transformer no gap is required in the transformer core so the transformer can be smaller and cheaper.
See https://www.tubecad.com/2014/09/blog0308.htm for further explanations.
Previous Topic: I didn't know about NOS tubes
Next Topic: Point to Point vs PCB
Current Time: Mon Nov 23 00:03:01 CST 2026
