Home » Sponsored » Pi Speakers » pi 10" midrange horn plan request
Re: pi 10" midrange horn plan request [message #87872 is a reply to message #87871] Tue, 24 April 2018 15:02 Go to previous message
Midhorn plans are shown in the links below. They're conical horns, meaning they use straight-sided walls in the horn flare. That makes them relatively easy to build. I'd suggest making a mock-up with cardboard, and then use your cardboard pieces as a template to cut your wood.
Information about the midrange horn used in our constant-directivity cornerhorns can be found in the following threads:
Previous Topic: Mid-horn Plans request
Next Topic: Pi 3 Sub Plans Request
Current Time: Sat Nov 21 21:17:54 CST 2026
