| Re: Contemporary record players with "vintage" feel [message #87832 is a reply to message #87824] |
Mon, 16 April 2018 17:42  |
gofar99
Messages: 2065 Registered: May 2010 Location: Southern Arizona
Illuminati (5th Degree) |
Hi, I would expect a nice one that has been refurbished to be in the $250 to $400 range. Anything less is likely either a con job or just cosmetics. Depending on how serious you are about getting one the higher end ones would be my choice. Beware of terms like "vintage", "collectable", "rare" etc.....often wording to make a somewhat common thing seem more valuable. There may be some all in one units like Panasonic with radios and even tape players in that range that would be fine as well.
If you run into something ....check out others like it by searching for that model on the web.
