Home » Sponsored » Pi Speakers » Dimensions clarifications
Re: Dimensions clarifications [message #87783 is a reply to message #87742] Tue, 10 April 2018 21:37 Go to previous messageGo to previous message
One last question on dimensions.
I am using 3/4" materials, and I am doubling the bass bin baffle. I made adjustments to the dimensions to maintain the bass bin volume. These adjustments end up shifting the driver deeper into the corner by 1 1/8".
Do I need to worry about this? And if so, where should I make up the difference? I know the purpose of the corner sections is to position the speaker correctly, should I just make those bits longer so the driver is the correct distance from the corner and the opening is the correct size?
Thanks for all the hand holding.
-Josh
Previous Topic: 4 Pi Home Theater Build
Next Topic: Acoustic damping 4pi speakers
Current Time: Sat Nov 21 19:36:10 CST 2026
