Home » Audio » Thermionic Emissions » Amp Kits
Re: Why? [message #8753 is a reply to message #8750] Wed, 26 January 2005 08:20 Go to previous messageGo to previous message
HI Douglas,
IN the standard transformer coupling, single ended situation, the major disadvantage of the method is the average DC current that flows in the circuit must be supported by the transformer, making the transformer relatively large so that it does not saturate due to the DC only. This is probably the most common output coupling method, as it is relatively simple. At quiescent conditions, the power supply voltage appears on the plate (minus a little loss due to the IR loss in the transformer. During signal conditions, the output swings above and below the supply voltage.
akhilesh
Previous Topic: Width Enhancer
Next Topic: Quick and simple formulae for Ra
Current Time: Mon Nov 23 01:31:18 CST 2026
