Home » Audio » Pro Sound » Removing background noise
Re: Removing background noise [message #87386 is a reply to message #87308] Tue, 06 March 2018 16:09 Go to previous message
Hi, I use it and have not had it add any noise. You might be using too small a sample rate. I use only 24/96 and 24/192 for input. It internally appears to use 32/XXX for making the changes. Exactly what sort of noise is it adding in your usage? What are you feeding in? What are you desiring as output? If you have hi-rez inputs and want say CD output format (or gasp! MP3) it will probably be noisier.
Previous Topic: Turntablism
Next Topic: Where can I find affordable music books
Current Time: Fri Nov 06 03:49:41 CST 2026
