Home » Audio » Source » Hi Res Turntable that records
Re: Hi Res Turntable that records [message #86974 is a reply to message #86970] Wed, 10 January 2018 20:56 Go to previous messageGo to previous message
Hi, It will certainly work...but hi-rez....dubious. The process of getting the best information (sound) from a record is not easy. It is easy to get some sound. How good...depends on the actual equipment. I believe I would list this turntable as one in the lower end of mid-fi. Probably OK for most casual use, but not hi-rez. To get there requires gear that is much higher up the quality and unfortunately cost scale. Three primary components are involved. First the cartridge (aka pick up). If it is not reasonable then everything else is a waste of time. Then the tone arm assembly. It must track the record accurately and with reasonable force. Finally the motor and platter assembly. It needs to be accurate with respect to speed and be quiet. The next part is pretty easy if you are going for something to do usb. Moderately good phonograph preamps with usb added on are surprisingly not too costly to make and sound moderately good. In this price range they are not the weak link. The other three components will be. If a listener is happy with MP3 level sound quality the turntable ought to be fine. If you are accustomed to hi-rez downloads, it will fall way short. I don't consider my gear (BTW I design and build commercial audio gear) as the really high end. My lowest cost cartridge was about $275, tonearm $350 and turntable with out either of those parts $600. My main system is significantly more. On it records sound exceptional.
So, buyer beware. It may function well for your needs and then it may not.
Previous Topic: Digital music unpopular with audiophiles
Next Topic: Cd player
Current Time: Sat Nov 07 00:27:57 CST 2026
