Home » Audio » Craftsmen » Learning to Solder
Re: Learning to Solder [message #86923 is a reply to message #69750] Tue, 02 January 2018 12:02 Go to previous messageGo to previous message
gstarey66 is currently offline  gstarey66
Another suggestion for reliable solder joints. Make the wire(s) and whatever you are solder to a good close mechanical connection before applying solder. You will not have failures from vibration or have the solder bridging large gaps (solder conducts, but not as well as copper).
Previous Topic: Type of Wood
Next Topic: Why the discrepancies?
Current Time: Fri Oct 30 03:59:25 CDT 2026
