Home » Audio » Source » How to play smaller records? Purchase new player?
Re: How to play smaller records? Purchase new player? [message #86523 is a reply to message #86521] Sat, 11 November 2017 19:52 Go to previous messageGo to previous message
Hi, The records with large holes are 45 RPM singles. Yes there are adapters to make them fit a more modern turntable. Some are snap into each record (a real pain) others are a type that fits on the center of the record player and are sort of like a big plastic washer. These are pretty cheap (under $5) and are available from many sources. The first thing I would do with your new player is verify that it has the 45 RPM speed. Nearly all do. If your record player is of an automatic stack loading type the issue is a bit more difficult as you will need to find the adapter that is designed for it. This can be difficult. If it is designed to play only one record at a time you should have no problems with the adapters.
Previous Topic: Will playing the records cause damage?
Next Topic: Is vinyl coming back?
Current Time: Sun Nov 08 11:31:43 CST 2026
