Home » Sponsored » Pi Speakers » New 3Pi build
| Re: New 3Pi build [message #86515 is a reply to message #86096] |
Fri, 10 November 2017 16:12   |
tubemax
Messages: 37 Registered: February 2012 Location: Netherlands
Baron |
OK, so here I'm again with some progress... trimmed all the panels to exact same size, succeeded to cut openings for woofer & horn along with T-nuts, it took me forever just to drill those bass ports, probably most difficult job I ever done with MDF ( I wish Wayne had some alternative design with standard plastic port size... ).
Now I can finally move to glueing everything together, then sanding, painting, sanding again, placing isolation, wiring... it could be ready in two weeks if all goes according to plan and yes I received Dummy load 100WATT 8 Ohm resistors from Parts-express so now is crossover complete as well...
btw, 100WATT resistor is actually not needed for 3 Pi if you using AE 12TDS if I'm not wrong?
New 3Pi build
By: tubemax on Sun, 10 September 2017 17:03
Re: New 3Pi build
Re: New 3Pi build
By: tubemax on Mon, 11 September 2017 12:34
Re: New 3Pi build
Re: New 3Pi build
By: tubemax on Sun, 29 October 2017 16:06
Re: New 3Pi build
Re: New 3Pi build
By: tom-m on Tue, 31 October 2017 22:11
Re: New 3Pi build
Re: New 3Pi build
By: tubemax on Fri, 10 November 2017 16:12
Re: New 3Pi build
Re: New 3Pi build
By: tubemax on Fri, 10 November 2017 17:12
Re: New 3Pi build
Re: New 3Pi build
By: tubemax on Sat, 11 November 2017 17:53
Re: New 3Pi build
By: tubemax on Sun, 19 November 2017 16:12
Re: New 3Pi build
Re: New 3Pi build
By: tubemax on Mon, 20 November 2017 15:18
Re: New 3Pi build
By: tubemax on Sun, 26 November 2017 10:49
Re: New 3Pi build
Re: New 3Pi build
By: tubemax on Tue, 12 December 2017 13:11
Re: New 3Pi build
Re: New 3Pi build
By: tom-m on Wed, 13 December 2017 12:22
Re: New 3Pi build
By: tubemax on Tue, 12 December 2017 16:34
Re: New 3Pi build
Re: New 3Pi build
By: tubemax on Sat, 16 December 2017 16:05
Re: New 3Pi build
By: tubemax on Sat, 16 December 2017 16:10
Re: New 3Pi build
Re: New 3Pi build
By: tubemax on Thu, 28 December 2017 15:13
Re: New 3Pi build
By: tubemax on Sat, 30 December 2017 18:19
Current Time: Mon Oct 12 04:27:56 CDT 2026
