Home » Audio » Thermionic Emissions » who likes drawing composite curves?
mmmhhh!...Class A [message #8631 is a reply to message #8630] Mon, 20 December 2004 07:36 Go to previous messageGo to previous message
Hey-Hey!!!,
Class A is soo much easier for a quick analysis. Draw the load line on the single tube curves, and then double it for the a-a primary load. This will usually give you a larger than expected number. The traditional a-a loads are from the 'Max Power' days for the most part.
If you want to look at an AB1 amp, all on a sudden things get more complex as the load changes from a-a/2 to a-a/4 when the other side cuts off. Not that that doesn't happen to a lesser extent in A...but, the first or second 'cut' analysis isn't going to need the details.
regards,
Douglas
....damn Thrintun!
Previous Topic: Homebrew amp schematics
Next Topic: Transformers
Current Time: Sat Nov 07 01:43:41 CST 2026
