Home » Audio » Room Acoustics » The appropriate absorption technology
Re: The appropriate absorption technology [message #86011 is a reply to message #86008] Thu, 31 August 2017 13:17 Go to previous message
See the "foam versus fiberglass" thread, which is on a similar topic. But I think there's also a little more to it than just what damping material is used. There is also the configuration used, which may be more to your point. Some people use panel absorbers for bass, others use bass traps which are cavity resonance absorbers. For higher frequencies, most use open cell foam "wedges" and other similar absorbent materials.
Previous Topic: The best listening position
Next Topic: Scattering of sound energy
Current Time: Mon Nov 02 08:29:33 CST 2026
