Home » Audio » Pro Sound » Cheap Gear
Re: Cheap Gear [message #85969 is a reply to message #85965] Sun, 27 August 2017 01:33 Go to previous message
moss24 is currently offline  moss24
Leot55 wrote on Sat, 26 August 2017 09:50
I think it's sensible to buy an inexpensive starter instrument when you're first learning. You can always sell it later and upgrade to a better version once you know it's something you want to stick with. But, I can also see the point of spending more upfront for better quality. I bet you might luck out if you buy a used instrument that's made by a trustworthy company known for making durable instruments.
Quite so Leot. On the other hand, it can also be worth it to (perhaps) hire an instrument or go for classes where there are a variety of good quality instruments. You can then purchase an instrument of choice, once your mind is made up.
Previous Topic: Ohm's law
Next Topic: Youtube filming equipment
Current Time: Fri Nov 27 04:18:21 CST 2026
