Home » Audio » Room Acoustics » Foam versus fiberglass
Re: Foam versus fiberglass [message #85909 is a reply to message #85905] Mon, 21 August 2017 20:24 Go to previous messageGo to previous message
There are a lot of things that go into making a great sounding room. Some are more important than others. Some are huge, other smaller "Nth degree" things. And sometimes, two different approaches solve similar acoustic problems to varying degrees.
For example, speakers with uniform directivity are able to mitigate many of the problems of room acoustics. So some speakers will sound better in a bad room than other speakers will in a good room. Of course, the best thing is to have great main speakers with uniform directivity and multiple subwoofers in a well damped room. But that's not always possible. So sometimes, you have to work with what you've got.
Anyway, foams and fibrous damping materials work pretty well at damping higher frequencies. They can't solve room modes, but they can help with things like ceiling slap.
Previous Topic: The corners
Next Topic: Best place to purchase.
Current Time: Mon Nov 02 05:08:04 CST 2026
