Home » Audio » Home Theater » USB Drive Won't Play
Re: USB Drive Won't Play [message #85744 is a reply to message #85737] Sun, 30 July 2017 15:08 Go to previous messageGo to previous message
Look for the "input" button on your remote control. If you can't find it on your cable remote, look on the remote that came with your television. Use that button to find the USB. When you see the screen, your options will pop up.
On my remote, the "input" button is at the top. If this didn't fix the problem, post again and I'll try to troubleshoot your issue. I display pictures on the television screen quite often for dinners, church, and other events.
Previous Topic: Would you buy the display?
Next Topic: Choosing a video display
Current Time: Sun Oct 18 10:43:48 CDT 2026
