Home » Audio » Thermionic Emissions » Nickel Wonder Line Stage
Re: Nickel Wonder Line Stage [message #8565 is a reply to message #8564] Wed, 17 November 2004 07:37 Go to previous messageGo to previous message
Simple and inexpensive. I like that. I can easily be done for under $100. Even if you use the more expensive Hammond power transformer.
Fred, can you give a listening impression. The 124B is rated for only 150Hz to 15KHz, same as Hammond's 125 series SE output trans. However, a lot of people who have used the 125SE's believe it operates very well outside of specs. JE Labs confirmed that it's actually +/- 1dB between 20Hz to 20KHz. Wonder if its the same for the 124 P/P series?
Gar.
Previous Topic: Transformers
Next Topic: re-capping vintage amps
Current Time: Sat Nov 07 01:43:32 CST 2026
