Home » Audio » Room Acoustics » The corners
Re: The corners [message #85625 is a reply to message #85622] Thu, 13 July 2017 16:29 Go to previous message
I took that inference from the OP comments too.
I digressed a bit about how a speaker must be acoustically close to the corner to gain the benefit of constant directivity. That is a significant fact, very important for the proper implementation of a constant directivity cornerhorn.
But like you said, if a person uses constant directivity cornerhorns that are designed and setup properly, they won't have any early reflections. The wavefront launch is perfectly pure. No other loudspeaker configuration can do that indoors, so it sounds different than other loudspeakers. It is sort of like headphones.
Previous Topic: Room acoustic problems
Next Topic: Foam versus fiberglass
Current Time: Mon Nov 02 03:55:00 CST 2026
