Home » Audio » Home Theater » For how long should a system last?
Re: For how long should a system last? [message #85562 is a reply to message #85508] Fri, 07 July 2017 14:11 Go to previous messageGo to previous message
gofar99 wrote on Tue, 27 June 2017 16:13
As long as the media you are viewing/playing doesn't change I would say about 5 years. If there is a change, all bets are off. The actual gear may survive a long time but be totally obsolete.
True gofar; you raise a good point about the gear being rendered redundant. There isn't a guarantee that the media being viewed or played won't change so I was wondering, what if there was a possibility of the gear being modified to suit emerging formats?
Previous Topic: Packing your system
Next Topic: Buying similar brands
Current Time: Mon Nov 09 06:51:07 CST 2026
