Home » Audio » Room Acoustics » Placing speakers against the wall
Re: Placing speakers against the wall [message #85123 is a reply to message #85119] Sat, 06 May 2017 11:20 Go to previous messageGo to previous message
Hi, I'm sure Wayne will have the best answer on this...but when you place a speaker against a wall it reduces the space it has to work into. Hanging in the middle of a room it sees about a full spherical space, on the floor about a 1/2 sphere, against a wall 1/4 sphere and in a corner 1/8th. This dramatically increases low frequency response. However, it will almost certainly harm mid range and high frequencies. Some problems possible are a "hole in the middle" sound spectrum because the speakers are too far apart to create a central image. Basically exaggerated separation. Too much reflection from side walls of high and mid frequencies. Probably other stuff I missed. All of this means you ought to move the speakers around to find a good compromise. I find with many speakers that sitting on the floor is OK, but I like the sound best when they are about 3-4 feet away from the rear and side walls. This would vary depending on the actual size of the room.
Previous Topic: Scattering of sound energy
Next Topic: Total Harmonic Distortion
Current Time: Mon Nov 02 10:55:19 CST 2026
