Home » Audio » General » Audio missing?
Re: Audio missing? [message #85116 is a reply to message #85107] Fri, 05 May 2017 03:01 Go to previous messageGo to previous message
vhfspeeks is currently offline  vhfspeeks
If you've checked that the sound is turned on on the tablet, and in the application you are using to run the files, then there are a few things it could be. If it plays other sounds fine, then it's might be an incompatibility with the files cwemoy suggested. Otherwise you could check if your tablet needs to update its drivers.
Previous Topic: Gamings headphones for music?
Next Topic: Earphones to use when jogging
Current Time: Tue Oct 20 21:59:15 CDT 2026
