Home » Audio » General » No sound on laptop
Re: No sound on laptop [message #84512 is a reply to message #84464] Wed, 08 February 2017 07:20 Go to previous messageGo to previous message
vhfspeeks is currently offline  vhfspeeks
First check that it isn't muted. There might be a sound icon at the bottom, and if you click on that it will show what the sound level is. If it isn't muted, have you tried external USB speakers? If USB and HDMI work then you might have a problem with your onboard speakers. If you can, use windows update or something similar to update the sound drivers in case there's a software error.
If all of that fails, then take it to the shop!
Previous Topic: Long Term Investment?
Next Topic: Using your phone
Current Time: Tue Oct 20 22:25:34 CDT 2026
