Wayne Parham Messages: 19108 Registered: January 2001
Audio is AC, so positive and negative terms don't apply. However, sometimes (often) the connections are still labeled that way, and it generally means positive voltage on a positive terminal will cause positive pressure, e.g. forward diaphragm motion at the speaker.
One key factor is whether the interface is balanced or unbalanced; Shielding is important for unbalanced connections, and most commercial audio preamp connections are unbalanced. For speaker wires, the main thing is the conductor size. In all cases, you want a good quality connector because the contact is a potential trouble spot.
