Home » Audio » Thermionic Emissions » tube friendly speakers
Re: tube friendly speakers [message #8385 is a reply to message #8381] Tue, 03 August 2004 11:28 Go to previous message
Can't tell if you are spelling Spendor when you spell sendors. I have lot of experience with Spendors and still think they are one of the most musical speakers ever. Try Waynes site, the Pi speakers work perfectly with tube amps and sound great and priced very reasonable. But if you are committed to the Sendors I can attest that they all work well with tube amps, very flat impedance curve consequently easy load for tubes. 20 watts should suffice unless you are a headbanger then you should not even considor the Spendors anyway. Waynes Pi 2's do it all with tubes try them. Spendors sound best on Classical music not so fine on rock or pop. The Totem Arro's don't have great rep with tubes according to common knowledge. Hope this helps,J.R.
Previous Topic: ECL82 / 6BM8
Next Topic: Looking to step in
Current Time: Sun Nov 29 17:45:27 CST 2026
