gofar99 Messages: 2060 Registered: May 2010 Location: Southern Arizona
Hi
"I read that vinyl's most glaring weakness compared to the CDs or the digital formats is the bass. Vinyls can't capture the low-end bass sounds as good as their competitors."
Humm....I get an easy 20HZ with my system. To be truthful there really is very little in any media except for DVDs of movies below 50HZ. I have all of those capabilities plus reel to reel tape. The response (bass or other) is dictated by: the musician, the recorder, the mix and finally the quality of the disk or other thing that is at the end of the chain. I have as many CDs with so-so bass as LPs. If you go out and get a Crosley record player and say the bass in poor...sure. Same holds true for nearly anything in that price range. This is unfortunately the great divide. A reasonable turntable and the stuff that goes with it is certainly more costly than an iPod (or other similar device). Vinyl reproduction is more costly, but good gear (of either type) will not have deficient response as you have been led to believe.
