Home » Audio » Speaker » Mono "flanking sub"
Re: Mono "flanking sub" [message #83342 is a reply to message #81624] Thu, 11 August 2016 14:54 Go to previous messageGo to previous message
jonone is currently offline  jonone
Something I found.
"Low-pass frequency for flanking subs should be between 80Hz and 150Hz, and use second-order or third-order for best results. Fourth-order can be used, but it doesn't sound as good to me - It doesn't blend as well. The higher the slope, the higher the the crossover frequency. So for example, second-order at 90Hz or 100Hz often works well, third-order is better around 125Hz and fourth-order usually has to be set higher still. Set the amplitude for SPL matching the mains in the overlap band."
Previous Topic: One Speaker Wi-Fi
Next Topic: Class d for flanking subs
Current Time: Fri Nov 06 22:52:37 CST 2026
