Home » Audio » Speaker » Mono "flanking sub"
Re: Mono "flanking sub" [message #83022 is a reply to message #83020] Fri, 15 July 2016 10:25 Go to previous messageGo to previous message
Self-interference notches are very apparent in measurements. And they line up exactly as you would expect: At the frequency where path length distance causes a 180° shift, you'll see a 10dB to 20dB notch.
As for subwoofer volume, setting is pretty easy: Just match the subs to the mains. If you have measurement gear, you can set it for overall smooth response. Or you can dial it by ear pretty easily.
Previous Topic: One Speaker Wi-Fi
Next Topic: Class d for flanking subs
Current Time: Fri Nov 06 22:52:06 CST 2026
