Home » Audio » Thermionic Emissions » dynaco
Re: dynaco [message #8297 is a reply to message #8296] Tue, 29 June 2004 20:01 Go to previous messageGo to previous message
metasonix is currently offline  metasonix
Any Dynaco is good. If you just need a small amp for low-power listening, the SCA-35 or ST-35 are great. If you need more power, look for a decent ST-70 (they got loved a lot, so finding one in good shape is difficult). And get Mark IIIs if an ST-70 isn't enough.
BEWARE of units showing rust--it really ate those chassis quickly, and rust is usually a sign of abuse or neglect. Such amps almost always need new filter capacitors, and often new power tubes. Once rebuilt they are as good as new amplifiers in performance. Ebay can be a dangerous place to look for old tube amps, so be aware of this. If you win a bid, tell the owner that you won't accept an amp that has a bad transformer, lots of rust, or other major problems. If they act squirrely, CANCEL the bid.
Previous Topic: Vintage amp "fuzzies"
Next Topic: Why does flawed vintage amp sound so good
Current Time: Sat Oct 17 08:32:17 CDT 2026
