Home » Sponsored » Pi Speakers » Taking the 7Pi to the next level (Modifications of the 7Pi Loudspeaker)
Re: Taking the 7Pi to the next level [message #82929 is a reply to message #82897] Sun, 26 June 2016 12:03 Go to previous messageGo to previous message
Nelson Bass
Hi Johnny,
The spider isn't replaceable and it's function is primarly to center the voice coil.
I rely on my amplifiers to control drivers and their excursion. Razz
Yes, I switched from 4Pi's to 7Pi's. With the 7Pi's I have better bass integration in my listnening room and better midrange.
If you're used to be sitting close to the 4Pi's and are enjoying their chest pumping effect you should not upgrade to 7Pi's as you will loose that effect.
I don't use my 3Pi subs with the 7Pi's. I've plenty of bass without and prefer the cleaner setup.
Previous Topic: 2 Pi Tower Plans
Next Topic: Pi-eyed
Current Time: Sun Nov 01 13:47:02 CST 2026
