Home » Audio » Craftsmen » In need of a new multimeter
Re: In need of a new multimeter [message #82539 is a reply to message #82527] Fri, 29 April 2016 15:12 Go to previous message
Hi, You didn't specify if it was portable or a bench model. FOr a bench model (can also travel as it has batteries) I use a Mastech MS8040. Circuit Specialists has them. I expect others do as well as it is a absolute clone of one of their own brands that I killed (ran over it with the car) a while back. Excellent features. Triplet would be a "portable" one I would check out. Many others out there from $10 and up. You do to some extent get what you pay for. The $10 ones are less accurate and prone to failing.
Previous Topic: Soldering with Shaky Hands
Next Topic: Make Your Own DIY High-End Cables
Current Time: Mon Nov 09 06:19:49 CST 2026
