Home » Audio » Source » Cleaning old records
Re: Cleaning old records [message #82536 is a reply to message #82501] Fri, 29 April 2016 09:18 Go to previous messageGo to previous message
minora is currently offline  minora
gofar99 wrote on Tue, 26 April 2016 07:22
Hi, you should look at the forum on vinylengine.com for info on this. There are lots of ways to clean LPs. Some quite simple like using non-concentrated Dawn dish soap and water. It gets more complicated from there. I personally use an ultra sonic bath type cleaner (with a water, wetting agent, drops of Dawn and some isopropol alcohol. This is followed by a distilled water rinse and a vacuum dryer. It will take a really grimy LP and make it quite nice in a matter of minutes. A popular LP cleaner is "SpinClean" Google it. For about $75 you get all you need to do about 100-150 LPs. Refills are cheap as well. It works pretty well.
Hi, thanks for the information. I'll look around for more info. I see some methods are more complicated than others. Is it related to the age of the records or how 'dirty' it looks?
Previous Topic: Replacing a CD lens
Next Topic: Cables with custom length
Current Time: Mon Nov 09 04:51:26 CST 2026
