Home » Audio » Source » Cleaning old records
Re: Cleaning old records [message #82501 is a reply to message #82492] Mon, 25 April 2016 18:22 Go to previous messageGo to previous message
Hi, you should look at the forum on vinylengine.com for info on this. There are lots of ways to clean LPs. Some quite simple like using non-concentrated Dawn dish soap and water. It gets more complicated from there. I personally use an ultra sonic bath type cleaner (with a water, wetting agent, drops of Dawn and some isopropol alcohol. This is followed by a distilled water rinse and a vacuum dryer. It will take a really grimy LP and make it quite nice in a matter of minutes. A popular LP cleaner is "SpinClean" Google it. For about $75 you get all you need to do about 100-150 LPs. Refills are cheap as well. It works pretty well.
Previous Topic: Replacing a CD lens
Next Topic: Cables with custom length
Current Time: Mon Nov 09 04:51:20 CST 2026
