Home » Audio » Measurement » Are there any good books about audio measurement?
Re: Are there any good books about audio measurement? [message #82119 is a reply to message #78011] Thu, 25 February 2016 19:55 Go to previous messageGo to previous message
HearForYourselfAudio is currently offline  HearForYourselfAudio
I agree with the previous comments about both the books and the pitfalls of measuring in a listening room. I find that gated measurements are the best way to eliminate room effects. In my impromptu rig, I actually go outside. I take my speaker and place it on the top of a step ladder. The mic is then set a meter away. A 12 ft (3m) ladder gives you reflection free measurements down to roughly 100Hz. That should be good enough for crossover design purposes. Low frequency performance can be made using a ground plane technique, which can then be spliced with the "gated" data. This technique is outlined in the books mentioned.
Let your ears do the judging... www.hearforyourselfaudioreview.com
Previous Topic: Software for optimizing multi sub parameters
Next Topic: Octave in Hertz
Current Time: Sat Nov 21 16:08:29 CST 2026
