Home » Audio » Radio » Local radio station signal
Re: Local radio station signal [message #81881 is a reply to message #81857] Mon, 04 January 2016 17:01 Go to previous messageGo to previous message
Hi, It could be either. Radio stations are rated in various power output. It is part of the licensing for the station. Some are as little as 100 watts (rare and mostly on colleges) and others up to 50,000 watts. Most likely the one you like is in the 5000 watt or lower power range. If other stations come in fine then probably the antenna is OK. Depending on the vehicle it could be a real challenge to replace it.
Previous Topic: Radio isn't working
Next Topic: Discovering New Stations
Current Time: Wed Nov 04 03:24:49 CST 2026
