Home » Audio » Home Theater » Reflection in TV
Re: Reflection in TV [message #81828 is a reply to message #81000] Thu, 24 December 2015 18:29 Go to previous messageGo to previous message
Pioneer wrote on Wed, 07 January 2015 17:57
I was wondering how this could be possible, but I never would have thought the solution would be a matte finish to the glass. Does it affect visual quality at all? Do TV, movies, etc., look just as good through a matte finish as they do through a smooth one?
Supposedly,
The matte finish is less bright, if all else is equal.
A trick to reducing reflections is to mount the panel tilting downward (out more into the room) at the top of the panel, than at the bottom.
I've had luck placing my flat screen with a high gloss glass screen, against the wall with the most Windows , if there are any.
Try not to let too much ambient (or direct) light exist out in front of the screen.
Easier said than done if not in a dedicated home theater.
Previous Topic: So excited! New house
Next Topic: Theater system shopping
Current Time: Sun Nov 08 08:17:04 CST 2026
