Home » Audio » Thermionic Emissions » Will increasing the primary imodance of my output trannies hurt?
Re: Will increasing the primary imodance of my output trannies hurt? [message #8175 is a reply to message #8173] Thu, 20 May 2004 13:21 Go to previous messageGo to previous message
Steve is currently offline  Steve
Hi Akhilesh,
Yes, an increase in primary Z will generally lower distortion, lower the output Z of the amp (increase damping factor), and the HF response might be just slightly lower, depending on the OPT. Higher order harmonics may raise their head a little, but if the design is good, this may not be a problem.
If the tubes are run class A, there won't be any increase in output tube life. IF the output tubes are run AB, life should be increased, but to what extent depends on the idle current, plate dissapation etc.
Hope this helps.
Previous Topic: anyone heard a Darling amp here?
Next Topic: Initial review of ASUSA (Antique Sound USA) K2003 SET amp
Current Time: Thu Sep 24 14:38:02 CDT 2026
