Home » Audio » Thermionic Emissions » low channel output problem
Re: low channel output problem [message #8167 is a reply to message #8165] Mon, 10 May 2004 09:47 Go to previous messageGo to previous message
First thing I would try is to swap the tubes between the 2 channels see if it still acts that way. If does then I'd check the voltages at the tube bases. But be careful EXTREMELY HIGH VOLTAGES there. If it follows the tubes when you switch them around you could have just a bad tube.
HTH
Bill W.
Previous Topic: Electro-Harmonix 2A3 replacement for Valve Art 2A3
Next Topic: cap replacements
Current Time: Thu Nov 05 13:54:49 CST 2026
