| 7-pi conversion [message #81642] |
Sat, 31 October 2015 13:05  |
tromic
Messages: 2 Registered: October 2015
Esquire |
Hello!!
I built a pair of seven pi a couple years ago, here is a picture of the right speaker!
These have been my main speakers for a long time but last year, we moved into a house and our open kitchen-living room is cruelly lacking both corners for proper installation... On the right, there is a window and on the left, a hexagonal turret leading to the kitchen. I then bought a Sonos home theater, which is not bad, but just don't rival the seven pi that were hooked to a home made 8W tube amp.
So, now I'd like to convert these seven pi into something else that still sound good and won't require two corners. I will probably be using oak this time also, not mdf.
Any idea what I can do with these? I'd like to use all 3 drivers for a rich sound but the four pi is using only 2...
I built my seven pi on this :
-Eminence PSD2002 with compressed plastic horn
-Eminence Omega 15
-Mid range driver : Eminence Delta 10
-Standard x-over (Only option when I bought if I remember well)
If I remember well, the woofer is dephased from the rest... Would it be possible to revert the connection and move this to the front? What kind of air volume would I need in the cabinets? Front or rear-ported?
I know, lot of questions, but I built these a long time ago and it's hard getting back to this!
Thank you,
Michael
Attachment: pi.jpg
(Size: 62.89KB, Downloaded 4573 times)
