Home » Audio » Speaker » Hasty mistake
Re: Hasty mistake [message #81445 is a reply to message #81443] Thu, 09 July 2015 10:35 Go to previous messageGo to previous message
A genuine JBL recone kit is part number C8R2226 and can only be installed by an authorized service center. JBL does not sell these kits "over the counter" as a repair part. They only make them available to trained service centers.
So I am skeptical that the woofers are genuine. But really, the baskets alone are worth $100 each, even if the cones are completely missing. So you're not out of luck, even if the cones that are installed aren't good. You can get them reconed at a factory service center for about $150-200 each.
There can be any sort of problems with a second-rate cone, but what I see most often is weak HF response. Watch the response above 500-800Hz or so. You can measure that on a baffle, without needing to mount the drivers in a box.
Previous Topic: Attenuating B & C DE250 on Pi horn
Next Topic: My Speaker Project - Looking for Advice
Current Time: Sat Nov 07 02:54:02 CST 2026
