Home » Audio » Speaker » Horn Throat Constriction
Re: Horn Throat Constriction [message #81396 is a reply to message #81395] Fri, 12 June 2015 10:58 Go to previous messageGo to previous message
Two possible suggestions:
    1. Use push-pull drive. If you're going to have two drive units, you might as well take advantage of this configuration.
    2. Mount the drivers sideways to reduce (or possibly eliminate) the curve needed to feed the throat.
Previous Topic: My Speaker Project - Looking for Advice
Next Topic: Digging out the old (?) ART array - some questions
Current Time: Mon Nov 30 12:00:18 CST 2026
