Home » Audio » Speaker » Horn Throat Constriction
Re: Horn Throat Constriction [message #81387 is a reply to message #81386] Sun, 07 June 2015 14:05 Go to previous messageGo to previous message
PointSource is currently offline  PointSource
I knew in the back of my mind what your answer would be: model, build & measure! I have to decide whether the concept is worth the effort & expense.
The 2 sources don't actually combine at the throats; the 2 passages combine in parallel at the start of the common conical flare section. Either way, the 2 wavefronts will expand & impinge upon each other.
The goal is to achieve the longest path length within the given enclosure dimensions, including the use of 180-degree rounded curves. In order for the wavefronts to arrive at the conical flare relatively intact, I've surmised (guessed) that the passage width needs to be about a quarter of the upper frequency's wavelength. I'm concerned that the initial narrowing may pervert the waveform too much.
I'm working on a preliminary mechanical drawing (the old-fashioned way on 1/4 scale graph paper). I can post a photo in the near future if there's any interest....
Previous Topic: My Speaker Project - Looking for Advice
Next Topic: Digging out the old (?) ART array - some questions
Current Time: Fri Oct 16 12:57:23 CDT 2026
