Home » Audio » Speaker » Horn Throat Constriction
Re: Horn Throat Constriction [message #81385 is a reply to message #81384] Sat, 06 June 2015 22:13 Go to previous messageGo to previous message
PointSource is currently offline  PointSource
I got the idea that it might work from some old Altec Mantaray HF horns, which would collapse in the horizontal before expanding again. If such can pass HF, then why not midrange / midbass? The total throat area is just under 20in^2 for each 10" cone, so the front chamber area isn't too large (was also thinking about filler). The passage collapses to 2.25" horizontally while the vertical remains the same as the throat height.
Of course, the Mantarays are expanding in the vertical thru the point of constriction, and the mid horn doesn't.
I'm exploring theoretical plausibility for the time being. If the negative responses outweigh the positive, then I've saved time & resources.
Previous Topic: My Speaker Project - Looking for Advice
Next Topic: Digging out the old (?) ART array - some questions
Current Time: Sat Nov 07 02:53:52 CST 2026
