Home » Sponsored » Pi Speakers » 4 pi speakers + 3 pi subwoofers, pics & measurements (How to interpret the measurements?)
| Re: 4 pi speakers + 3 pi subwoofers, pics & measurements [message #81374 is a reply to message #81371] |
Thu, 04 June 2015 10:19   |
You're right, there's more mutual inductance when they're positioned that way, close together and in the same plane. They are coupled together, and act sort of like a transformer. This causes the HF crossover to shift some, and even causes some of the energy from the woofer circuit to bleed into the tweeter circuit, and vice versa. But this woud be most evident in the crossover range, and even worset case, it's a fairly small effect. I wouldn't say it's trivial, but the coupling isn't so strong that it could create a 10dB boost or drop.
What we're seeing is HF rolloff, and by a pretty significant amount. I think it's probably the measurement system, and that the charts aren't giving an accurate picture. If they are, if there is something wrong with the crossover or drivers, then the HF is so low that these speakers would sound very dull, almost like no tweeter is connected at all.
By: chrisR on Thu, 28 May 2015 11:32
By: tom-m on Wed, 03 June 2015 18:12
By: tom-m on Fri, 05 June 2015 22:09
Current Time: Wed Oct 21 16:26:55 CDT 2026
