Home » Sponsored » Pi Speakers » Starting New Build, a Few Questions...
Re: Starting New Build, a Few Questions... [message #81236 is a reply to message #81235] Fri, 24 April 2015 11:08 Go to previous messageGo to previous message
The volume displaced by the H290C when mounted in the cabinet is approximately 65 cubic inches.
The crossover has no plate-through holes because I wanted one side to be perfectly flat so it could sit on a gasket and mount directly to the cabinet. Mount the components on the solder side and fasten the coils with a silicon adhesive. It acts as both a mount and a cushion for them. Mount the capacitors and resistors so that they sit a little bit above the board, supported by their leads.
Previous Topic: 4pi Cabinet Port Tuning
Next Topic: B&C DE250
Current Time: Wed Oct 21 16:36:34 CDT 2026
