Home » Sponsored » Pi Speakers » Four Pi Frequency Response
Re: Four Pi Frequency Response [message #81193 is a reply to message #81191] Sat, 07 March 2015 22:11 Go to previous messageGo to previous message
That looks good until you get down below 150Hz or so. What you're seeing is definitely less bass than normal. These kinds of (high-efficiency) speakers don't have the deepest bass response and are generally better with subs, but they have more output than that.
It could be that your microphone is responsible for the rolloff. It isn't a calibrated microphone, and so that might be what's causing it. Or it could be the environment or a combination of the two. But if that's the true measurement, then bass response is lacking and something is amiss.
To be honest, I usually see problems in the upper midrange when there's a qualitative problem with the cone. Cheap recones usually show up as having reduced output above 800Hz, which makes a hole in response. Since I'm not seeing that, I think the drivers are OK, but it's hard to say for sure. The bass output on your speaker is definitely not measuring right.
Previous Topic: Selling to Australia ?
Next Topic: 4 Pi Plans
Current Time: Sun Nov 08 10:10:05 CST 2026
