Home » Audio » Measurement » WTPro (Experienced Users?)
Re: WTPro [message #81113 is a reply to message #80871] Sat, 14 February 2015 10:27 Go to previous messageGo to previous message
Keith Larson is currently offline  Keith Larson
The user guide, release notes and quick start are all PDF files in the installation directory. If the PC environment is set up properly, the UG can be opened via F1 key or pull down menu. Another option is to use an external program to view the PDF files. The PC environment is usually set up when you install something like Adobe acrobat.
As far as registering on the BBS goes, the challenge question is what is the abbreviation "TS" stand for. Its "Thiele Small". After entering the data the BBS software queries your ISP's mail system to see if the email address is valid. If there is a delay (which is what likely happened) it will fail.
Direct email contact, use tech@woofertester.com
Previous Topic: Ping Wayne
Next Topic: Software for optimizing multi sub parameters
Current Time: Fri Oct 16 19:58:01 CDT 2026
