Home » Sponsored » Pi Speakers » Speaker placement and wavefront launch, revisited
Re: Speaker placement and wavefront launch, revisited [message #81028 is a reply to message #81027] Thu, 22 January 2015 15:52 Go to previous messageGo to previous message
George Swanson is currently offline  George Swanson
I never received it so thanks twice for the response! There's something screwy about my comcast account and I need to get it sorted.
The link is very interesting. I'll tell you about my room and you can tell me if the Seven Pi speakers would work. The room is 12 feet by 21 feet and the speakers would be on the short wall. They are good corners and the listening position would be at the far end of the room from the speakers. The far end of the room is actually an opening into a much larger room with a vaulted ceiling.
Are you up and running with mid horn flat packs yet? I'd understand if not due to the move and other things going on in your life right now.
Are you a dealer for all the components of the kits (drivers, etc.)?
Thanks,
George
Previous Topic: One more Four Pi crossover question
Next Topic: Tim's 4Pi Speaker Build
Current Time: Fri Oct 02 15:04:50 CDT 2026
