Home » Sponsored » Pi Speakers » One more Four Pi crossover question
Re: One more Four Pi crossover question [message #81022 is a reply to message #81021] Mon, 19 January 2015 22:35 Go to previous messageGo to previous message
The lugs may be coated with shallac or something similar. You might want to cut the lugs and solder directly to the wire.
We insert the wire into 0.205" lugs which connect to the circuit board. So we don't use the screw-mount lugs. I think those screw-mount lugs are coated, and depend on the fasterner to bite through the coating to ensure electrical connection.
Previous Topic: Rs in Four Pi Crossover
Next Topic: Speaker placement and wavefront launch, revisited
Current Time: Tue Oct 20 13:48:48 CDT 2026
