Home » Sponsored » Pi Speakers » Tim's 4Pi Speaker Build (Description of My 4Pi speaker build)
Re: Tim's 4Pi Speaker Build [message #81018 is a reply to message #81017] Thu, 15 January 2015 00:06 Go to previous messageGo to previous message
timkur is currently offline  timkur
Insulation
This was pretty straightforward. The only R13 insulation I could find at Home Depot was faced (has the brown paper backing on it), but that made it really easy to install. For the back, side, and top, I glued the paper backing to the inside of the speaker box. Pretty simple. For the insulation on the cross brace, I removed the paper, so as not to interfere with the absorption of the insulation.
I installed the insulation before I glued on the top of the speaker box. It made access very easy.
Insulation on the back and side.
index.php?t=getfile&id=1632&private=0
Insulation sitting on the cross brace.
index.php?t=getfile&id=1633&private=0
And then I glued the insulation to the top before I glued the top onto the box.
index.php?t=getfile&id=1634&private=0
Next up, the 2nd baffle, and cutting those curved corners for the waveform. I was able to successfully do it on a test piece. We'll see how it works when I do it for real. Smile
Tim
Previous Topic: Speaker placement and wavefront launch, revisited
Next Topic: Ordered new waveguide H290C
Current Time: Tue Sep 29 18:55:47 CDT 2026
