Home » Sponsored » Pi Speakers » Tim's 4Pi Speaker Build (Description of My 4Pi speaker build)
Re: Tim's 4Pi Speaker Build [message #80972 is a reply to message #80971] Sun, 04 January 2015 01:57 Go to previous messageGo to previous message
timkur is currently offline  timkur
Cross Bracing
I see that a lot of folks built their 4pis and attached the back as the last piece. I thought about that, but then I couldn't figure out how to get the cross bracing installed, so I decided to leave the top for the last piece to glue on.
I had some leftover 1x2 maple from a cabinet I installed, and decided to use that. The plans say to install the cross braces with a "slight amount of preload". I took that to mean that they should fit really tight, so I cut the braces 1/16"-1/32" too long, and really wedged them in there. They weren't going to move easily, but I glued them in to be safe.
index.php?t=getfile&id=1604&private=0
index.php?t=getfile&id=1605&private=0
Thanks!
Tim
Previous Topic: Speaker placement and wavefront launch, revisited
Next Topic: Ordered new waveguide H290C
Current Time: Tue Oct 20 17:26:26 CDT 2026
